1988 Chevy Truck rough throttle acceleration ..now IAC goes
1988 CHEVROLET TRUCK
160,000 MILES • V8 • 2WD • AUTOMATIC
JEFF NEWTON
Engine performance problem originally started out as horrific stumble with occasional backfire when giving throttle AFTER engine is at normal operating temp. When engine is cold will run smooth at idle AND when given throttle. Once engine temp. reaches approx 180, engine will run smooth at idle however will stumble, cough,buck, backfire when giving throttle, especially when under load (driving). Smelly exhaust. No codes initially. However, eventually did get a code 45, (rich fuel mixture). Code has not reappeared since cleared. Today, same problems, however, after letting engine run for about 20 minutes and periodically goosing the throttle, the stumbling has stopped when throttle is given. Now however, when you put truck in gear the IAC immediately increases from 35 to 145 on SCAN tool. Engine temp. goes from 190 to 215; and because IAC has gone so high engine revving at 2500 rpm with no application of throttle. Putting trans in neutral IAC drops back down to about 45 and eventually coolant temp will drop back down to 190. Originally thought throttle position sensor (TPS)was a problem. Lowest it reads is .62 v, but does climb when throttle is given (max reading I have seen on tool was 2.5v), but does seem a bit sluggish..maybe supposed to be, I don't know if there is an intentional time delay built into the output of this device. I bought the TPS to replace it, but once the IAC started its immediate "jump to the moon" when trans is taken out of park, I'm surmising it really isn't the problem now. I've read other inquiries made regarding oxygen sensors and MAF. Tool reads O2 measurements which regularly switch from "lean" to "rich" to "lean", etc. which I understand it is supposed to do. Guessing MAF at this point, but since the problem "changed" I'm at a loss on this one. What do you guys think? MAF, O2 sensors, TPS ??? I have no doubt computer and IAC are doing their jobs. Any guidance appreciated. Truck computer/ throttle body performance has been exceptional up to this point... but is not "drivable" as it is now.
Jan 31, 2009 at 11:16 AM
HESITATION, SAG, STUMBLE
Tips Click a link to view tip
Tech1Question: Stalling and stumbling
SYMPTOM DEFINITION
Momentary lack of response as accelerator is depressed. May occur at any vehicle speed. Usually most severe when first trying to make vehicle move. May cause vehicle to stall if severe enough.
POSSIBLE CAUSE & CORRECTION
Perform careful visual check.
Check fuel pressure. See CHART A6 - FUEL SYSTEM PRESSURE TEST chart in the TBI TESTS/CODES article in this section.
Check for water contaminated fuel.
Check TPS for binding or sticking.
Check fuel pump cycle system.
Check ignition timing.
Check alternator output voltage. Repair if less than 9 or more than 16 volts.
Check for open HEI ground circuit No. 453.
Check canister purge system.
Check EGR valve operation. See EGR SYSTEM CHECK chart in the TBI TESTS/CODES article in this section.
Check for incorrect or defective CALPAK or PROM.
TPS should rear .45 at closed throttle and at WOT at 4.5volts
Jan 31, 2009 at 11:44 AM
