1988 Chevy Truck Overdrive Transmission
122,000 MILES • V8 • 4WD • AUTOMATIC
JBRO
Truck will not pull in overdrive from dead stand still. If you start in drive, then get to highway speed and shift into overdrive, it works fine. Thoughts?
Feb 10, 2008 at 10:20 AM
JOHNYPHANTOM
  • 37 POSTS
honestly i dont think you should be pulling anything in overdrive , if thats waht you are ssaying . if your just saying that you cant take off ( without towing anything ) in selector is in overdrive , then the lockup convertor may be bad
Feb 12, 2008 at 1:54 AM
