I have replaced plugs, cap, rotor, wires, ECM, throttlebody gasket (sucking air).
Idle at start up is around 2000 rpm and stays pretty steady. No codes come up on the scanner.
Nothing seems to change rpm. Any Ideas Please.
Friday, May 23rd, 2008 AT 11:11 AM
BLACKOP555
MECHANIC
Does idle go down when the vehicle warms up any? Or does it stay high all the time?
Disconnect the IAC that help? Check for vaccum leaks.
SPONSORED LINKS
Friday, May 23rd, 2008 AT 12:47 PM
PEGAN
MEMBER
Stays at around 2000 rpm can't get it to idle down.
Disconnected IAC no diffrence.
