Engine Performance problem
1988 Chevy Truck V8 Two Wheel Drive Automatic
ecm good. Replaced TPS, MAP, O2 AND IAC and now will not idle
Sunday, June 14th, 2009 AT 2:48 PM
DR LOOT
MECHANIC
You did not tell me why you did all that work, go back and recheck your work make sure everything is together correctly and that you did not damage the wire loom, make sure all the vacuum lines are back on.
