Hi:
Yes it sounds seezed. What you can try is to spray a little penetrating oil in the cylenders, let it sit, and take a breaker bar and see if you can turn the engine at the crankshaft. Chances are even if you do get it loose, there will be internal damage, but you may get luckey enough that it may still run.
Let me know what happens, of if you have other questions.
SPONSORED LINKS
Monday, June 28th, 2021 AT 9:58 AM
