1988 chevy K1500 1/2 ton 4wd
BUBBA_175
i have a 1988 chevy k1500 1/2 ton 4wd with a 350 i believe it is stuck in 4 high the reason i think this is when i drive it over 50-55 it overheats and it won't shift into overdrive i have tried the water pump, the thermostat, and checked the tranny fluid and none of this has seen to help the overheating problem or the shifting. how would i go about finding out if it is stuck in 4 high and how to get it out
Apr 11, 2007 at 6:43 PM
  • 75,988 POSTS
[quote:58e701a04a="Bubba_175"]i have a 1988 chevy k1500 1/2 ton 4wd with a 350 i believe it is stuck in 4 high the reason i think this is when i drive it over 50-55 it overheats and it won't shift into overdrive i have tried the water pump, the thermostat, and checked the tranny fluid and none of this has seen to help the overheating problem or the shifting. how would i go about finding out if it is stuck in 4 high and how to get it out[/quote:58e701a04a]
Try the TCC solenoid
Apr 11, 2007 at 7:39 PM
