1987 Chevy Truck Temperature Range of my analog temperature
78,000 MILES • V8 • 2WD • AUTOMATIC
LNGFISH
This is a 454 P30 Chevy Motor home. The temperature needle has no numbers on it. It works fine. What would the 50%, middle, temperature indicate? When should alarm go off?
Apr 26, 2009 at 3:13 AM
DCS1998
  • 41 POSTS
[quote:7d109de1d4="LNGfish"]Engine Cooling problem
1987 Chevy Truck V8 Two Wheel Drive Automatic 78000 miles
...The temperature needle has no numbers on it. It works fine. What would the 50%, middle, temperature indicate?...[/quote:7d109de1d4]
I would say roughly, about 10-15 degrees higher than your stock thermostat temp is.
Since most gauges are set to read "straght up" if everything is ok.
Apr 26, 2009 at 4:36 AM
