Engine Mechanical problem
1987 Chevy Truck V8 Four Wheel Drive Automatic
I just got a 87 chevy truck with the 350 v8 TBI fuel system. The LH gas tank fuel pump is shot but the RH works. When i turn the key to start it will not start unless i go and pour a little gas down the barrel then it will fire and run fine. I have to do this every time I turn off the key. What would be causing this?
Aug 28, 2010 at 3:06 PM
