1987 Chevy Truck V8 Two Wheel Drive Automatic
motor is in a street rod. Temp goes up to around 200. Has no thermostat in it. Do not drive in the cold weather. Just started getting hot. The radiator was just recored. Now the carb did stick the float open and filled the crank case with fuel. I ran it a little. Then changed oil and filter. Ran good then started overheating did this have anything to do with the overheating? The engine is a stock 350. Any ideas please I am stumped on this. Thanks
SPONSORED LINKS
Sunday, August 23rd, 2009 AT 6:05 AM
