1986 Chevy Truck Starter and soleniod
1986 CHEVROLET TRUCK
STARCRAFT1998
Electrical problem
1986 Chevy Truck V8 Four Wheel Drive Automatic unknow miles
truck was worked on prior to my arrival to the schene starter was removed. I aquired new rebiult starter I am not sure which of the small posts on the solenoid to use. Vehicle is a old military chevy P.U. with 6.2 lt deisel.
Sep 10, 2010 at 12:56 AM
How many small wires do you have other than battery/fusible link wires -you should have a purple one-the starter you got right now has an ignition bypass circuit-meaning it will apply full battery voltage to the ignition coil
Sep 10, 2010 at 1:03 AM
