I believe your truck has a carburetor is that correct?If it does it also has a secondary fuel filter inside the carburetor where the fuel line attaches, you will need a 1'' inch wrench and a 5/8'' line wrench to replace it, also you may be having choke problems, have you checked the fuel pressure from the mechanical pump?
SPONSORED LINKS
Friday, June 19th, 2009 AT 10:18 AM
