Kent Shank
Hutchinson, Kansas
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Give the technician the cold-versus-warm symptom history and the list of unsuccessful replacements. Request testing while the fault is present before replacing more parts.
Source: Original question and visible replies. Owner outcomes are attributed; other participants' experiences are not treated as this owner's repair. Next steps are editorial guidance, not a confirmed diagnosis.
1985 Corvette
A 1985 Corvette ran poorly after bodywork and an engine-compartment wash, according to its owner. Numerous ignition parts were replaced. A later mass-airflow-sensor replacement made no difference; the remaining problem occurred while the engine was cold.
Reported outcome: The owner reported no improvement from the replacement mass-airflow sensor. No final repair was documented.
The reported timing after the wash does not prove what was damaged. The exact burn-off-module code and cold-condition test results were not provided.
