dash and tail lights
CLE_0109
Electrical problem
1984 Chevy Truck V8 Four Wheel Drive Manual unknow miles
dash and tail lights do not work and i checked the fuse and it is fine... they stopped working the other night when i did a burn out i have no idea what the problem is...
Sep 2, 2010 at 5:44 PM
JDL
  • 16,098 POSTS
Its sounds like you have a headlight switch that is out. Here is a guide to help you see where you are losing power.
I'd have to check the feed to and from the headlamp switch. At the rear of vehicle brown wire is voltage for the tail lights. I'd check the bulb-- bulb sockets-- wire harness at the rear. That brown wire should be hot/voltage with the headlamp switch turned on, use a voltage tester. Do the headlamps work ok?
Any applicable fuses, you have to use a voltage tester on the fuse circuit. There are two applicable fuses. One may be hot all the time and the other goes hot with the light switch turned on, check those fuses both ways, light switch on and off. One way or the other they should be hot. Instrument light fuse and tail fuse where applicable.
Check out the diagrams (Below)
Please let us know what you find.
Cheers
Sep 3, 2010 at 2:08 AM
