1984 Chevy Truck Brakes
AARON2010
Brakes problem
1984 Chevy Truck V8 Four Wheel Drive Automatic
Replaced brake pads and calipers on driver and passenger side front, bled them multiple times in correct order. PR,DR,PF,DF. i can build decent pressure with truck off but when i start it they go to the floor and i can barely stop
Feb 7, 2010 at 8:48 AM
HMAC300
  • 48,601 POSTS
when you first gt in your truck try pumping the brakes. If the pedal comes up then there is a good possibility that the master cylinder is bad. this is taking for granted that there is no air in the system.
Feb 7, 2010 at 9:41 AM
