Engine Mechanical problem
1983 Chevy Truck V8 Two Wheel Drive Automatic
I have an chevy camaro and i gust had an used engine put in out of a 83 chevy truck it is a 350 small block. the engine is losing gasoline from the carb, the lower block under the water pump and shooting it out of the hose that conects to the carberator please could you give me some advice thanks.
May 30, 2009 at 1:02 AM
