1982 Chevy Truck Ignition Key
LSCROGGINS
  • 1982 CHEVROLET TRUCK
Interior problem
1982 Chevy Truck 6 cyl Two Wheel Drive Manual
How do I remove the Key switch and tumblers?
Sunday, November 29th, 2009 AT 1:12 PM
DR LOOT
  • 2,311 POSTS
First of all, you will have to remove the steering wheel, removed the horn button, and you will have access to the nut for the steering wheel, you will need steering wheel puller, . Once you have the steering wheel off, you will need another special tool to remove the steering wheel lock plate, (all of these tools are available for rent at your local parts store) you will need to remove the turn signal switch, once you have done that. There is a screw that holds the ignition lock in position removed that screw and the ignition lock will pull straight out.
Sunday, November 29th, 2009 AT 10:55 PM
