1981chevy stepside wont start
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have battery condition and the starter-command circuit checked, including loaded supply and ground measurements, before condemning the starter.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for testing loaded electrical circuits. Use the actual vehicle wiring and specifications.
Discussion summary
A 1981 Chevrolet pickup would not crank even though the owner described the battery as charged and the lights worked. Replies suggested a ground connection, fusible link or ignition-switch circuit.
Reported outcome: No test findings or completed repair were reported.
Working lights and a reported full charge did not document available starting power. Other owners' similar experiences were not diagnoses of this truck.
