1981 Chevy Truck vacuum leak
100,000 MILES • V8 • 2WD • AUTOMATIC
WSTX65
i have 81 chevy pick up i have already rebuilt the rochester carb put all the gaskets check all the area vac hoses spraying carb cleaner but the carb still makes a terriblre hissing sound and thetruck has a terrible miss please help
May 3, 2009 at 1:10 PM
DCS1998
  • 41 POSTS
Did you check the vacuum hose that goes from the intake to the brake booster?
May 3, 2009 at 2:27 PM
WSTX65
no i didnt is there a certain procedure to do this if so can you tell me what should be done .
May 3, 2009 at 11:53 PM
