I have an 81 chevy 1/2 ton, with 350 turbo auto trans. While its in park, you can put it in drive or reverse and it works but will not shift into 2nd or 3rd gear. Also if your sitting still idling and you pull it all the way down to low 1 and try to shift it back up, it free slips until it finally catches a gear. Any ideas? It does the same thing if you grab the piece coming out the side of the trans. And move it from park to low 1, it has about a 60 degree slip before it catches and then clicks back up.
SPONSORED LINKS
Monday, June 14th, 2010 AT 12:57 AM
