1980 Chevy Truck Where's the ground for the instrument pane
1980 CHEVROLET TRUCK
15,000 MILES • V8 • 2WD • MANUAL
SPLATTGRAPHICS
  • 10 POSTS
My gauges all go wacky when I turn on the headlights. The dash won't light, the directionals both glow dimly. Everything works fine out on the body, but
I suspect a bad ground for the instrument panel.... Where is that on an old Chevy pickup?
Sep 17, 2009 at 3:31 AM
JDL
  • 16,098 POSTS
Welcome to the forum. My wiring info is limited on your model year. Usually the dash lights get feed from the headlamp switch. Check the fuses, instrument or gage fuses, use a testlite to make sure the fuse circuit is hot. The fuse may not go hot unless the headlamp switch is on, just depends on how it's wired? I don't have a location for the ground, at the dash, the ground wire is black, if you suspect a problem, try a redundant ground, see if it helps.
Sep 17, 2009 at 4:17 AM
