1980 Chevy Truck oil
1980 CHEVROLET TRUCK
LYLEJR
  • 6 POSTS
Smells problem
1980 Chevy Truck V8 Four Wheel Drive Automatic
I have a strong smell of gas in the oil, the oil also seems very thin.
Feb 9, 2009 at 10:18 AM
Carbuerator or EFI fuel system?
Feb 9, 2009 at 12:18 PM
LYLEJR
  • 6 POSTS
It has a aftermarket edelbrock carb
Feb 9, 2009 at 12:59 PM
Check the float system needle valve might not be seating or the float has a pin leak and sinking
Feb 9, 2009 at 3:13 PM
TOOFFY
[quote:ee56c0caa3="lylejr"]Smells problem
I have a strong smell of gas in the oil, the oil also seems very thin.[/quote:ee56c0caa3]
Sounds like the truck is running alittle rich. does it ping? try a high octain in gas. There is no water in oil is there?
Feb 9, 2009 at 4:33 PM
LYLEJR
  • 6 POSTS
No i haven't heard a ping and there is no water in the oil. I am going to rebuild the carb and replace the fuel pump before i drive it again. Im sure the fuel in the oil is affecting the lubrication of the oil and don't want to cause engine damage.
Feb 10, 2009 at 5:10 AM
RACEFAN966
  • 5,029 POSTS
Don't forget the change the oil and filter too.
Feb 14, 2009 at 5:26 AM
STEVESBS1
  • 11 POSTS
also check your fuel pump diaphragm may be bad letting gas in the engine
Feb 23, 2009 at 4:09 AM
