my truck just started to run rough I looked at the oil pressure gage It was at 0. I took it home (about 1/2 mile) and turned it off.
Jan 29, 2010 at 3:10 AM
✓Experienced Mechanic
No oil pressure could mean oil pump failure-check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal/zero could mean oil pump and engine bearings
