how do you bleed the brake system .and also is the vacum line comming off the brake system important
Apr 22, 2010 at 7:25 AM
HMAC300
✓Experienced Mechanic
if you have the vacuum line off the booster it wil be very hard to operate. yes it's important. you bleed the brakes right rear-left rear-right front-lft front. that's the correct procedure. try a power bleeder for bleeding though, that will give the best result.
