1979 Chevy Truck
JONNYPETERS
  • 1979 CHEVROLET TRUCK
  • V8
  • 90,000 MILES
The engine is a 350 v8 out of a 79 chevy truck.
Swapped in to a 1985 s10.
When you apply pressure to the accelerator there is a hesitation, then jerks and then accelerates. I have replaced the spark plugs, plug wires, distributor cap, rotor button and fuel filter and installed a curve kit.
Friday, February 19th, 2010 AT 7:45 PM
Check if the choke plate is fully opening, the accelerator pump if its squirting fuel and ignition timing
Friday, February 19th, 2010 AT 8:04 PM
JONNYPETERS
Okay,
when I have the truck idle and I press on the peddle you can hear and feel the hesitation its at the first moment I step on a little. If I flore it it does this as well. But it I feather it a couple times then acclerate it does not slug down.
Timming is correct. Choke plate is opening. When I manualy acclerate the pick up with my hand you dont get the hesitation but on the peddle it does.
Friday, February 19th, 2010 AT 10:28 PM
