1979 Chevy Truck
CASEY35
Shakes or Wobbles problem
1979 Chevy Truck V8 Two Wheel Drive Manual
Does the bottom ball joint need to be pressed when you put the new one in? Thanks!
Apr 13, 2008 at 4:29 AM
MIKE H R
  • 3,094 POSTS
the bottom ball joint needs to be pressed in, a ball joint press is used, in some auto stores the press is available to be borrowed to press it in.
Apr 14, 2008 at 3:52 AM
