1978 Chevy Truck what would cause the auto transmission fr
DANCASSIDY
MEMBER
1978 CHEVROLET TRUCK
V8
2WD
AUTOMATIC
89,000 MILES
This vehicle won't upshift out of first gear. Please let me know what can cause this. Thanks
Tuesday, February 3rd, 2009 AT 10:53 PM
BOWTIE BABY
MEMBER
If the modulator is bad or the vacuum line disconected it will not shift until about 25 or 30 mph. Check to make sure vacuum line is hooked up and you are getting vacuum to the modulator. If you are then you will have to replace the modulator, there fairly cheap(20-30dolars) and easy to change. It is located at the back of the tranny on the passenger side.
SPONSORED LINKS
Friday, February 6th, 2009 AT 2:40 AM
DANCASSIDY
MEMBER
Thanks, we checked the modulator and governor, changed the oil and filter too. Checked to be sure the detents matched on the tranny and the shifter. It refuses to upsift at all no matter what speed. Dan
Friday, February 6th, 2009 AT 10:37 AM
BOWTIE BABY
MEMBER
Well its hard to tell without driving the truck myself. You might want to take it down to a local tranny shop for a diagnostic, sometimes you can get them free, Aamco has free diagnostics sometimes. You might also want to check the shifter linkage to make sure it is going all the way into drive.
