1978 Chevy Truck starting
1978 CHEVROLET TRUCK
TRVL4SURE
Electrical problem
1978 Chevy Truck V8 Two Wheel Drive Automatic
Just happened. Turn key to start and nothing, battery good, lights bright. Jiggled gear shift to see if that helped still nothing. The interior light dim just a little bit when I hit the start position whith key.
Nov 29, 2008 at 8:15 AM
  • 110,194 POSTS
Hi:
It sounds like the starter. Remove it and have it bench tested at a parts store. If it's good, check the starter relay.
Dec 10, 2008 at 10:45 AM
