1978 Chevy Truck rust in fuel
120,000 MILES • V8 • 2WD • AUTOMATIC
RALAWSON
this truck has dual tanks, it seems to get what looks like rust into the carb. enough thru the filter to cause problems. is it common for this age vehicle to get rust in the tank. What could be the fix for this problem
Aug 18, 2009 at 3:38 AM
JDL
  • 16,098 POSTS
Hello, I'd have to drop the tanks and take a look inside. Sometimes you can clean them, if it is worth the trouble? Maybe you need a new tank/s? I might also replace the fuel lines. I have seen people use more than one inline fuel filter, but?? I don't think that is the correct fix.
Aug 18, 2009 at 3:56 AM
