1978 Chevy Truck dang radiator
1978 CHEVROLET TRUCK
CHEVYBONES
Engine Cooling problem
1978 Chevy Truck V8 Four Wheel Drive Automatic unknow miles
my truck started overheating this weekend, by overheating i mean it blew ALOT of coolant out of the overflow hole on the radiator, I figured it was a thermostat so I replaced that. Same thing so I replaced the radiator cap still nothing. So i replaced the water pump, STILL hot. It is running around 205-210. would my radiator be causing problems like this? would getting it cleaned fix this or should I just replace it?
Oct 20, 2008 at 3:46 AM
JNOVACK
  • 723 POSTS
you can take it to radiator shop and have it tested but is there a Catalytic Converter still on it that could cause that probbom if it is cloged
Oct 20, 2008 at 8:40 AM
CHEVYBONES
THERE in NO catylitci converter or any other form of emmissions
Oct 20, 2008 at 10:18 AM
JNOVACK
  • 723 POSTS
ok i would ta radiator to shop and have them test it for cloggs
Oct 21, 2008 at 9:23 AM
