1977 Chevy Truck BOTH BLINKERS BLINK AT THE SAME TIME
1977 CHEVROLET TRUCK
95,000 MILES • V8 • 4WD • AUTOMATIC
KENT JONES
BOTH BLINKERS BLINK AT THE SAME TIME,I HAVE NEW LIGHT HARNESS FRONT AND REAR ,IF YOU TURN THE RIGHT BLINKER ON THEY BOTH BLINK AND THE LEFT SIDE MARKER BLINKS AND VISE VERSA.IT DOESNT MATTER WITCH SIDE I TURN ON THEY BOTH BLINK.
Sep 10, 2010 at 2:50 PM
MADMIKE1735
  • 951 POSTS
check all your bulbs.... one bad bulb will make this happen...
Sep 10, 2010 at 2:51 PM
MADMIKE1735
  • 951 POSTS
have you looked into your turn signal switch? they get pricey, assuming your a do-it-your-selfer, without owning a power-probe, its really hard for me to tell you which component is bad.... my advice is check the flasher.... there maybe 2.... a turnsignal flasher, and a hazard flasher.... chances are one of the 2 are bad.... look into those before the switch..... they are alot cheaper also.
Sep 10, 2010 at 3:32 PM
