1976 Chevy Truck pickup wont start
98,000 MILES • V8 • 4WD • MANUAL
ALLAH
My name is alex almer i am 18 and in dire need of help with my pickup at first it would run but not quite right so it was the carb that was messed up and as soon as we took the stock one off we put on a brand new edelbrock 750 carb but as soon as we tryed to start it it back fired up trough the carb and never started after that we put the orginal one back on and that didnt work either so PLEASE HELP...
Mar 15, 2009 at 11:22 AM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 15, 2009 at 12:30 PM
