1976 Chevy Truck air leak
KHWANTS2KNOW
Brakes problem
1976 Chevy Truck V8 All Wheel Drive Automatic
ive been trying to get the brakes working on my 76' Chevy truck and have discovered an air leak at the master cylinder. It is leaking from in between the master cylinder and the brake booster where the master cylinder bolts on. Can this be fixed and how do I go about fixing it?
Feb 28, 2010 at 12:55 PM
  • 31,937 POSTS
When you say air leak, are you suggesting that air is entering the master cyl or there is a vacuum leak from the booster?
mark (mhpautos)
Feb 28, 2010 at 2:10 PM
KHWANTS2KNOW
i cant say. i havent taken it apart yet. the only thing i know is that when i squirt it with soapy water i can see air bubbles coming out where the master cylinder bolts onto the booster
Feb 28, 2010 at 3:09 PM
  • 31,937 POSTS
This will be a failed booster, you will not be able to over haul it your self, best to get a change over unit fitted, this will be cheaper and quicker.
mark (mhpautos)
Feb 28, 2010 at 5:45 PM
