Engine Mechanical problem
1975 Chevy Truck V8 Two Wheel Drive Automatic
i need help setting timing on a 400 sb chevy engine.with a 292 comp cam,with a 4010 4 barrel holly carb.with a square bore elbrock intake and i have a hei dist.i have a reg timing light.how can i set the timing . you cant use the book specs becauce the cam is to big. thanks
Aug 25, 2010 at 1:25 PM
