1975 Chevy Truck abrupt braking
1975 CHEVROLET TRUCK
104,000 MILES • V8 • 2WD • AUTOMATIC
CSTOUT2000
I own a 1975 Chevy C10 Scottsdale that has been sitting for over a year and we've bled the entire brake system since our repairs are complete to get it up and running. It's always had very (touchy) brakes that stop on a dime. My question is why would the right side front and rear brakes tend to lock up and also the rear seems to act as though it's not releasing as it should. When applying the brakes they go so far then abruptly grab. The rears have new drums and brake cylinders installed by Midas before we had to park it for repairs. She's had all brake work done, system bleed, including the front rotors lathed. Can the proportion valve be the culprit? Is it possible that the front caliper on that side is sluggish? I have had a problem with the rear brakes heating up too much so we had Midas rebuild the cylinders..Thanks
Hi, I was finally able to take it for a test run today for 25 miles or so and the brakes seem to be normal once again. I believe that sitting for so long tends to make everything tight and stick somewhat. Midas agreed. I'll check out all parts and hoses though just to be sure and bleed all the old fluid one more time. Hopefully there'll be no more lock ups. Thanks for the help :)
Jan 7, 2008 at 1:21 PM
2CARPRO JACK
  • 11,533 POSTS
As far as the r/f locking up...Be sure all sliders are lubed and working properly.Inspect the brake hose carefully. The rears....Sometimes remanufactured brake shoes dont have the proper arc to them,this will cause the incorrect amount and area of the shoe to make contact with the drum and the brakes will lock up.Try new brake shoes and be sure the adjustment isnt too tight, the e-brake should go down a little when applied. This could be a cause of the rears overheating
Jan 8, 2008 at 5:53 AM
