1973 Chevy Truck Won't start
SNOWCATS95
Engine Mechanical problem
1973 Chevy Truck V8 Two Wheel Drive Automatic
I just replaced the fuel pump 2 months ago, and ran flawlessly until just recently. The engine will crank, but not fire (Same symptoms it had before I replaced pump). I primed the carburator, and it started but died after the fuel ran out. Fuel pump checked out o.k, so back at square one. According to receipts from previous owner, the carb was rebuilt 19 years ago. Could this be the cause? If not, what else could it be? Thanks for your help.
Jul 7, 2009 at 6:56 PM
  • 75,988 POSTS
If the fuel pressure is okay and it fires up till the fuel ran out -I suggest you check that carb thoroughly or replace it -fuel filter okay?
Jul 7, 2009 at 10:50 PM
SNOWCATS95
yep, replaced filter at the same time as the pump, looked clean. Thanks for verifying my hunch about the bad carb. Definitely will look into it.
Jul 7, 2009 at 11:43 PM
