1972 Chevy Truck valve adjustment
JESSE2915
Engine Mechanical problem
1972 Chevy Truck V8 Two Wheel Drive
I just got done adjusting my valves and i got some popping sounds coming thru the exhaust,was wondering if it might be the valve adjustment or maybe the timing,i just put a new cam in and had the heads gone thru,also put a gear drive timing set in.sbc 305
Feb 3, 2009 at 10:49 AM
SMITHS AUTO REPAIR
try adjusting the valves again. did you adjust the valves with or without the engine running?
Feb 4, 2009 at 2:45 PM
JESSE2915
i did it with the motor off,i tried with motor runnung but the gear drive was to loud couldnt really tell when the rockers were clacking,
Feb 5, 2009 at 7:15 AM
BOWTIE BABY
  • 101 POSTS
It sounds like your valves might be too tight, loosen them about a quarter turn at a time each until the popping goes away. Is your geardrive the adjustable kind. If it is you will need to set it at 0 degrees and make sure your timing marks are lined up. I would do the valve adjustment 1st, its a lot easier. Check your firing order and timing too.
Feb 5, 2009 at 6:33 PM
