1971 Chevy Truck Help
99,000 MILES • V8 • 2WD • AUTOMATIC
BIGBLOCKERM
I have a 400 trans. that I just overhauled and it was doing fine now it will not shift in to 3rd. I have checked for vacume leaks linkage position fluid level and all seam to be fine. The motor is a 427 and it is built up a little. I hope you can help.. Thanks. Shannon
Feb 13, 2009 at 11:03 AM
PEAR69
  • 1,482 POSTS
If all your checks are good -- and the tranny ran after the overhaul -- then change the tranny fluid and filter again. Check for a smell or sight of burnt tranny fluid. If the new clutchs didn't soak in tranny fluid overnight (during the overhaul) they could have worn a little causing a clogged or sticking valve.
Make sure there are no vacume leaks..
Feb 13, 2009 at 4:37 PM
BIGBLOCKERM
Thank you very much. I will check the fillter and see what I get. I allso was told to readjust the linkage. So I will do both. Again, Thank you..
Feb 14, 2009 at 9:35 AM
PEAR69
  • 1,482 POSTS
Keep me posted...
Feb 14, 2009 at 12:18 PM
