1971 Chevy Truck carburator
127,722 MILES • V8 • 2WD • AUTOMATIC
KBOUGARD
i have a 1971 chevy cheyenne truck. the truck only starts when you manually open the choke by hand. what can i do to fix this problem so the truck will start without raising the hood and manually opening the choke to crank it.
thanks for your time.
Nov 24, 2008 at 8:14 AM
  • 75,988 POSTS
You need to adjust the initial choke opening also make sure the plate is not binding
Nov 24, 2008 at 8:21 AM
