1970 Chevy Truck Truck Idle
1970 CHEVROLET TRUCK
JON521
Engine Performance problem
1970 Chevy Truck 6 cyl Two Wheel Drive Automatic
Why does my truck cut off when its idle? I have to keep pumping the gas to keep it running.
Feb 18, 2010 at 9:19 AM
Check and adjust ignition timing and A/F mixture and curb idle speed could be loading up with a partially closed choke plate.
Feb 18, 2010 at 10:51 AM
JON521
thanks i will do that, I also dont have an exhaust on the truck and the breather is off. could that effect it?
Feb 18, 2010 at 10:56 AM
Check the PVC valve and also the heat riser if its opening, to inlcude the thermostatic air cleaner if its opening too
Feb 18, 2010 at 11:00 AM
