1970 Chevy Truck Hard starting Chevy c20
JRYODER80
Engine Performance problem
1970 Chevy Truck V8 Two Wheel Drive Manual
My truck will run well once warmed up but it takes about 30 minutes to warm up. I leave it idle with the choke full out or it will stall. Also I lugs some when the throttle is fully pressed.
Jan 6, 2009 at 11:44 AM
  • 110,248 POSTS
It sounds like you have a manual choke. How far closed does it go when you close it from the truck? Also, the chugging sounds like a choke problem too. It sounds like it's clossing too much.
Let me know what you find?
Jan 8, 2009 at 7:52 AM
