1970 Chevy Truck drum pistions
RMARTINEZ8526
Brakes problem
1970 Chevy Truck V8 Two Wheel Drive Automatic
MY BRAKES EXPANDED WHILE I WAS FIXING THE LUG NUT AND STUDS NOW I THIN I BROKE THE PISTION AND CAN'T GET THE DRUM CAP BACK ON
Nov 6, 2009 at 1:01 PM
  • 31,937 POSTS
Hi there,
If the piston has not dropped out and there is no fluid leaking, back off the bleeder and carefully ease the pistons back in to the wheel cylinder, re fit the drum and re bleed that wheel.if the piston has dropped out you will need to do some cleaning and re assembling first so let me know what it is at.
mark (mhpautos)
Nov 6, 2009 at 3:42 PM
