1970 Chevy Truck Carb problem
TONYBARROSO
Engine Performance problem
1970 Chevy Truck V8 Two Wheel Drive Automatic
carb is a 3310-10 750 with vacume secondarys.
when gas is put into the rear float boal (even when bench testing it) fuel leaks out of the rear idle slots.
any ideas?
Mar 5, 2010 at 11:17 AM
DR LOOT
  • 2,311 POSTS
I recognize the carburetor number it is a holly 750 vacuum secondaries, I don't understand your question because the secondaries do not have "rear idle slots" you better explained to me again exactly where the fuel is leaking from.
Mar 5, 2010 at 4:53 PM
