1969 Chevy Truck truck wont move
250,000 MILES • V8 • 2WD • AUTOMATIC
TOPBADDOG
  • 5 POSTS
I did an engine swap in my truck. I swapped a 305 with another 305. I used same TH350 trans. as before. Trans was working fine before the swap. Now it seems like it wont go into any gear. What could be wrong?
Nov 12, 2009 at 6:51 AM
DOCFIXIT
  • 18,828 POSTS
Was torque converter checked if seated into oil pump? was converter easily turned when bolted to flex plate?
Nov 12, 2009 at 7:09 AM
