1966 Chevy Truck turn signals
TIM1968
Electrical problem
1966 Chevy Truck Two Wheel Drive Automatic
turn signals are off but the flasher is still blinking without showing on the signal indicator light, what could be my problem, also when I push the brakes the right turn signal stops?
Apr 30, 2009 at 10:23 AM
JDL
  • 16,098 POSTS
Hello, I don't any wiring info on your vehicle, but, if the brake and turn lite use the same bulb filament, check the turn signal switch.
May 2, 2009 at 6:51 AM
