1966 Chevy Truck gas gage problem
466,000 MILES • 6 CYL • 2WD • MANUAL
BIGO1953
MY GAS GAGE DROPS HALF WAY DOWN WHEN I TURN ON HEADLIGHTS AND MOVES WITH THE BLINKERS WHEN I USE THEM.
Mar 1, 2010 at 3:39 AM
HMAC300
  • 48,601 POSTS
you need to check the gronds first on your truck. battery to body, battery to engine , engine to body and any under the dash. If youstill have the problem then check the ground wire to the tank....
Mar 7, 2010 at 6:16 AM
