1966 chevrolet C10
HEWLETT2002000
I have a 1966 chevrolet C10 pickup with a 350 and 4-speed standard transmission, the odometer says 65000 but since this is not the stock engine and transmission i dont know what the engine itself has on it. when i got it i had it running in less than an hour, it runs great, but after i fixed the brakes and tail lights i tried to take it around the block and it only made it half way and died, it would start back up but would sputter and die again, so i figured it was the fuel pump so i replaced it with no luck. and the carb seems to be working fine other than the choke but thats not the problem. could it be the coil maybe? i have a project 1962 C10 with a new HEI distributer i installed and if theres a chance it could be the coil then i would just change them out. the one on the truck at the moment has points. if you know of anything else it could be please let me know.
thanks,
John
Jan 22, 2007 at 4:09 AM
INDYUKE
  • 416 POSTS
I ran across a '71 chevy with the same engine that would sputter and pop. Put a new carb and a new distributor on it. It turned out the new distributor contained the problem though it sounded like a faulty carb. I'm trying to remember if it was a bad ground connection or improperly tightened/adjusted points. Check to make sure you are getting spark to each spark plug consistantly. That will tell you if you have problems in the ignition system. Let us know.
Jan 22, 2007 at 4:56 PM
