1965 Chevy Truck
88,000 MILES • V8 • 2WD • MANUAL
MCARDLEP
Truck starts and immediately shuts off. Any ideas?
Sep 8, 2009 at 8:25 AM
DOCFIXIT
  • 18,828 POSTS
This a stock 65? what engine? points ignition?
Sep 8, 2009 at 8:34 AM
  • 75,988 POSTS
Turn key On check for battery voltage on the coil positive terminal do you have it-if not the ignition circuit is open or you have a defective ignition switch-
Or do this get a jumper wire connect one end to the coil positive terminal and the other to the battery positive post-did it continue to run if so check and test above-
Sep 8, 2009 at 8:37 AM
