1964 Chevy Truck carb problems
BIGWILL64
  • 1964 CHEVROLET TRUCK
  • V8
  • MANUAL
  • 90,000 MILES
Hey I have a 64 chevy truck with a 283 v8 that has a sputters like its running out of gas I have changed the fuel pump and filters and sending unit and blew out all the lines but it still seems like its cutting out not like a miss but like its fighting for fuel any ideas?
Monday, April 21st, 2008 AT 10:46 PM
MOPARNUT1393
  • 34 POSTS
See if a carb rebuild kit is available for the carb. If you pull the carb apart try to be careful when seperating the pieces due to gaskets and check balls once all has been disasembled use a good carb cleaner through all ports and passages and clean all dirt from bowls. Check to make shure float is adjusted correctly if you can purchase a carb kit for it the directions will show you have to set the float and go through the carb.
Monday, April 21st, 2008 AT 11:04 PM
