1962 Chevy Truck Cooling system over-heats
RWROBIN1
  • 1962 CHEVROLET TRUCK
  • V8
  • 39,000 MILES
Installed a 454 engine in 62 Chevy 1/2 ton. Did not change original radiator. Truck over-heats. My question is: 1. Is my radiator to small for engine; 2. Do I have a cracked head or leaking head gasket?
What test do I need to do to pin-point problem?
Monday, January 11th, 2010 AT 1:16 AM
When you installed the 454 did you check the thermostat on it if not do so-
I had no problem with a 74 Vega original radiator for a 4cyl with a 327 on it
You can try block and pressure testing to find where its leaking at-
Monday, January 11th, 2010 AT 2:24 AM
