09/94 chevy s10 p/u falls on face at normal oper. temp
THATGUY
i have a 09/94 chevy s10 p/u with 146111.4miles, ext. cab, 2wd, v-6 4.3 engine. vin num.1gccs19z5s8124171. i have replaced the spark plugs, spark plug wires, distributer cap, rotor, fuel filter, air filter, and pvc valve. when the truck is first started and cold she runs like a champ. then when it gets to normal operating temp. it falls on it face every time you go to give it gas. it will choke for about 10-20 secs then recovers and runs rather well. i hope i have provided enough information to get this problem solved. thank you p.s. i tried to make a donation but at the payment info screen i won't keep united states in the field.
Dec 13, 2006 at 5:54 AM
XOWEY
  • 113 POSTS
[quote:0b82aae36b="thatguy"]i have a 09/94 chevy s10 p/u with 146111.4miles, ext. cab, 2wd, v-6 4.3 engine. vin num.1gccs19z5s8124171. i have replaced the spark plugs, spark plug wires, distributer cap, rotor, fuel filter, air filter, and pvc valve. when the truck is first started and cold she runs like a champ. then when it gets to normal operating temp. it falls on it face every time you go to give it gas. it will choke for about 10-20 secs then recovers and runs rather well. i hope i have provided enough information to get this problem solved. thank you p.s. i tried to make a donation but at the payment info screen i won't keep united states in the field.[/quote:0b82aae36b]
have you had it scanned for codes yet?
Dec 13, 2006 at 2:50 PM
THATGUY
no i don't have a scan tool.
Dec 14, 2006 at 9:30 AM
